Batch import images into PDF template and save each image with different name  (Lu 73 fois) Partager ce sujet Imprimer
Rakesh Kumar  30 janvier 2021 : 14:14
Is it possible to import different images to a template form via batch script and save it with different names.
For ex - i have 100 different images in a folder and a template form with a image field. now i want to run a batch script so that all 100 images are imported in one form each and 100 pdf forms are made.
Thanks
bebarth  30 janvier 2021 : 19:11
Hi,
Attached is an example using 2 methods.
  • If the names of the images can be incremental.
  • If not, the list of the names must be pasted into a field.
Both wizard actions are included into the .pdf file.
In this example all files must be in the same folder.
Please let me know if that suits you.
