Le script ci dessous est en java. Il permet de calculer la distance entre deux points (latitude et longitude).J’ai essayé de le coller bêtement dans un champ sous acrobat mais il ne renvoie pas de réponse.Y’a t-il des adaptations à faire pour pouvoir l’utiliser sous acrobat?Aussi, j’aimerai avoir la distance en milles marin. Pour info, un mille= 1852 m.Je vous remercie par avance pour votre aide.
Cordialement,
* JavaScript function to calculate the geodetic distance between two points specified by latitude/longitude using the Vincenty inverse formula for ellipsoids.
* Original scripts by Chris Veness
* Taken from http://movable-type.co.uk/scripts/latlong-vincenty.html and optimized / cleaned up by Mathias Bynens <http://mathiasbynens.be/>
* Based on the Vincenty direct formula by T. Vincenty, “Direct and Inverse Solutions of Geodesics on the Ellipsoid with application of nested equations”, Survey Review, vol XXII no 176, 1975 <http://www.ngs.noaa.gov/PUBS_LIB/inverse.pdf>
* @param {Number} lat1, lon1: first point in decimal degrees
* @param {Number} lat2, lon2: second point in decimal degrees
* @returns {Number} distance in metres between points
function toRad(n) { return n * Math.PI / 180; };
function distVincenty(lat1, lon1, lat2, lon2)
var a = 6378137,
b = 6356752.3142,
f = 1 / 298.257223563, // WGS-84 ellipsoid params
L = toRad(lon2-lon1),
U1 = Math.atan((1 – f) * Math.tan(toRad(lat1))),
U2 = Math.atan((1 – f) * Math.tan(toRad(lat2))),
sinU1 = Math.sin(U1),
cosU1 = Math.cos(U1),
sinU2 = Math.sin(U2),
cosU2 = Math.cos(U2),
lambda = L, lambdaP,
iterLimit = 100;
do {
var sinLambda = Math.sin(lambda),
cosLambda = Math.cos(lambda),
sinSigma = Math.sqrt((cosU2 * sinLambda) * (cosU2 * sinLambda) + (cosU1 * sinU2 – sinU1 * cosU2 * cosLambda) * (cosU1 * sinU2 – sinU1 * cosU2 * cosLambda));
if (0 === sinSigma) {
return 0; // co-incident points
var cosSigma = sinU1 * sinU2 + cosU1 * cosU2 * cosLambda,
sigma = Math.atan2(sinSigma, cosSigma),
sinAlpha = cosU1 * cosU2 * sinLambda / sinSigma,
cosSqAlpha = 1 – sinAlpha * sinAlpha,
cos2SigmaM = cosSigma – 2 * sinU1 * sinU2 / cosSqAlpha,
C = f / 16 * cosSqAlpha * (4 + f * (4 – 3 * cosSqAlpha));
if (isNaN(cos2SigmaM)) {
cos2SigmaM = 0; // equatorial line: cosSqAlpha = 0 (§6)
lambdaP = lambda;
lambda = L + (1 – C) * f * sinAlpha * (sigma + C * sinSigma * (cos2SigmaM + C * cosSigma * (-1 + 2 * cos2SigmaM * cos2SigmaM)));
while (Math.abs(lambda – lambdaP) > 1e-12 && –iterLimit > 0);
if (!iterLimit) {
return NaN; // formula failed to converge
var uSq = cosSqAlpha * (a * a – b * b) / (b * b),
A = 1 + uSq / 16384 * (4096 + uSq * (-768 + uSq * (320 – 175 * uSq))),
B = uSq / 1024 * (256 + uSq * (-128 + uSq * (74 – 47 * uSq))),
deltaSigma = B * sinSigma * (cos2SigmaM + B / 4 * (cosSigma * (-1 + 2 * cos2SigmaM * cos2SigmaM) – B / 6 * cos2SigmaM * (-3 + 4 * sinSigma * sinSigma) * (-3 + 4 * cos2SigmaM * cos2SigmaM))),
s = b * A * (sigma – deltaSigma);
return s.toFixed(3); // round to 1mm precision
