abracadabraPDF › Forums › PDF – Général › Highlight first 2 greatest number
13 septembre 2021 à 07:02 #46658
Rakesh Kumar
ParticipantSir,
I have say 30 text fields in which user can input numbers, or text or leave it blank
now i want that when the user clicks a button then the first 3 greatest number is highlighted / changed color ignoring the blanks or the text values.
Also, last 3 smallest number to be highlighted / changed color.
Thanks
13 septembre 2021 à 19:45 #69621
Maître des clésHi,
Please try that for the 3 smallest numbers:Code:var theNumbers=[];
for (var i=0; i<30; i++) {
var f=this.getField(“theField.”+i);
f.strokeColor=color.transparent;
if (!isNaN(f.value) && f.value!=””) theNumbers.push();
// Ascending sort
theNumbers.sort(function(a, b){return a[1]-b[1]});
// reverse order sort
// theNumbers.sort(function(a, b){return b[1]-a[1]});
if (theNumbers.length) {
for (var i=0; i<3; i++) {
try {
this.getField(“theField.”+theNumbers[0]).strokeColor=color.red;
} catch(e) {}
}For the 3 greatest numbers, use the reverse order sort script line.
:bonjour:14 septembre 2021 à 01:06 #69622Rakesh Kumar
ParticipantSir,
The script is not working as intended…. this script is highlighting the first 3 entry of an array after sorting it in ascending ….. however i want the first 3 smallest number in the array to be highlighted after sorting… ie. removing the duplicates in the array.
for ex – original array = [8,3,4,2,2,2,3,5,6,4]
after sorting the array will be = [2,2,2,3,3,4,4,5,6,8]
so current script is highlighting 2,2,2 but my requirement is to highlight every entry which equal to 2,3,4 .Hope i was able to explain.
Same for the greatest one. it should highlight first 3 greatest number after sorting in descending order avoiding duplicates.thanks.
14 septembre 2021 à 07:11 #69623bebarth
Maître des clésOK, I understood!
I will have a look later in the day.
:bonjour:14 septembre 2021 à 07:21 #69624Rakesh Kumar
Participant@Bebarth
please check your email, the issue has been solved and i have sent you the working pdf file on your email.. plz check and let me to know if it can be improved.
thanks
14 septembre 2021 à 18:50 #69625bebarth
Maître des clésHi,I don't have a lot of things to tell you!
I didn't know your UArr function, so I would have written the script like this:Code:var arr=[];
var f=this.getField(“theField.” + i);
if (!isNaN(f.value) && f.value!=””) arr.push(f.value);
var dv=arr.sort(function(a, b){return b – a});
function uniqueValue(anArray) {
return anArray.filter((val, ind) => anArray.indexOf(val)===ind);
var myarr=uniqueValue(dv);
for (var j=0; j<30; j++){
var g=this.getField(“theField.” + j);
if (g.value == myarr[0]) g.fillColor=color.red;
else if (g.value == myarr[1]) g.fillColor=color.green;
else if (g.value == myarr[2]) g.fillColor=color.magenta;
else if (g.value == myarr[3]) g.fillColor=color.yellow;
else {g.fillColor=color.transparent;}
this.getField(“Text1″).value=”Greatest 4 unique numbers are : ” + “nn” +” “+ myarr[0] + “n”+” “+ myarr[1] + “n”+” “+ myarr[2] + “n”+” “+ myarr[3];I allow myself to share both files.
:bonjour:15 septembre 2021 à 04:04 #69626Rakesh Kumar
ParticipantSir,
Somehow your script is not working and throwing an error in console ,
ReferenceError: val is not defined
8:Field:Mouse UpThanks
15 septembre 2021 à 13:39 #69627bebarth
Maître des clésHi,
That's working fine for me! I usually check the script works fine before sharing…
Attached is a new version checking the numbers in both orders.
:bonjour:17 septembre 2021 à 04:53 #69628Rakesh Kumar
ParticipantThanks for the updated version… but this also not working………….
I will send you video of the same, if that would help in sorting out the issue.
Thanks
17 septembre 2021 à 17:35 #69629bebarth
Maître des clésbonjour,
Je vois qu'il y a eu 4 téléchargements.
Quelqu'un d'autre pourrait-il me dire si le script fonctionne ou pas pour elle/lui ?Hi,
I see 4 downloads have been done.
Could someone else tell me if the script works fine for her/him or doesn't work?@+
:bonjour:18 septembre 2021 à 02:26 #69630Rakesh Kumar
ParticipantSir,
Attached is the video link from downloading the file to testing it .. and error which console shows.
https://www.dropbox.com/s/pmpgu1bodg0d7f6/issue.avi?dl=0
Please have a look. Hope this would help to solve the issue.
Thanks
18 septembre 2021 à 17:06 #69631bebarth
Maître des clésHi,
I don't understand why the function doesn't work for you. I did a test on both PC and Mac and the file works fine with both OS.
As your UArr fonction works fine too, you can you it for the file.
I placed the script in an other funtion. That avoids to get it twice in the buttons:Code:// Document Scriprs
function UArr(a){
var newArr=[];
for (var i=0; i < a.length; i++) {
if (newArr.indexOf(a)===-1) newArr.push(a);
return newArr;
function greatORsmall(wichOne) {
var arr=[];
if (wichOne==”greatest”) {
var dv=arr.sort(function(a, b){return b-a});
var dv=arr.sort(function(a, b){return a-b});
var myarr=UArr(dv);
for (var i=0; i<30; i++){
f.fillColor=color.transparent;
if (f.value == myarr[0]) f.fillColor=color.red;
else if (f.value==myarr[1]) f.fillColor=color.green;
else if (f.value==myarr[2]) f.fillColor=color.magenta;
else if (f.value==myarr[3]) f.fillColor=color.yellow;
this.getField(“Text1″).value=””;
if (myarr.length!=0) {
if (myarr.length>4) var nbNumbers=4;
else var nbNumbers=myarr.length;
if (nbNumbers==1) this.getField(“Text1″).value=”The unique number is:”;
else this.getField(“Text1”).value=”The “+nbNumbers+” “+wichOne+” unique numbers are:”;
for (var i=0; itry {
this.getField(“Text1”).value+=”nu2022 “+myarr;
} catch(e) {}
}// Mouse up action scripts
// greatest and smallest buttons
greatORsmall(event.target.buttonGetCaption());// reset button
f.value=””;
f.fillColor=color.transparent;Please try the new file and let me know.
:bonjour:19 septembre 2021 à 03:03 #69632Rakesh Kumar
ParticipantThanks, it is now working for me.
also, i have sent 2 or 3 issue on your email.. plz check and let me know if its possible.
Thanks again.
